old hydraulic fluid- What to do?
   / old hydraulic fluid- What to do? #1
caps
Montross Virginia
New Holland TC26DA
I am about to change the hydraulic oil in my tractor and will end up with about 6 gal of used
oil after changing it out. The question is what do I do with the old oil. Is it good for anything useful? Or do I just have to take to the dump recycling place. Seems like a waste to just have to dump it.
   / old hydraulic fluid- What to do? #2
unless you got a waste oil burner.. recycle it.
I usually keep a coffee can full of hyd oil to put rusty tools in and such.. but 90% of it goes to the recycle palce..
   / old hydraulic fluid- What to do? #4
Burn it or recycle it, that's about it.
   / old hydraulic fluid- What to do? #5
Recycle, where I live they have a separate place at the county where you take hyd oil. I have 10 gallons myself ready to go.
   / old hydraulic fluid- What to do? #6
I store at least 5 gallons of used stuff after I strain it for " emergency " use. Especially if it is going to leak out again. Better to leak out old stuff getting the tractor back in the garage than a $45 pail of new stuff. Swap out older pails for newer ones as I change the oil. I like to change mine yearly. Blew a line on Christmas eve once plowing snow, got 2 foot overnight. Was able to repair the line, but no place was open to buy oil. Sure was glad I was able to plow the drive. Drained and refilled a few days later. As I swap it out I save a little to burn brush and recycle the rest.
   / old hydraulic fluid- What to do? #7
Hydraulic fluid is good to help burn brush pile? I had no idea, gotta try it.
   / old hydraulic fluid- What to do? #8
Just recycle it.
Chris
   / old hydraulic fluid- What to do? #9
A guy with a waste oil stove down the road gives me 50 cents a gallon for mine. Before him I recycled it.
   / old hydraulic fluid- What to do? #10
I'm extremely careful about keeping it, and the drain pails clean. I've a friend with a bunch of old FarmAll ag tractors that leak(some of them badly). He uses it to top off his tractors
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
Utility Trailer (A52377)
Utility Trailer...
kids dirt bike (A53424)
kids dirt bike...
