Mar 29, 2013 / old gas can #1 S sal64 Platinum Member Joined Mar 5, 2009 Messages 535 Location ny orange county Tractor jd 2320 jd 990 jd950 HELLO ALL i have an old plastic gas can my dad used it for diesel for years, is it safe to just swiss it out with gas and start useing it again for gas? i hate to through it out these old cas cans are gold today. tu
Mar 29, 2013 / old gas can #2 Loadstar Platinum Member Joined Mar 16, 2012 Messages 791 Location Evansville, IN Tractor Ford 640 Yea you should be fine doing that. Even if you don't get every little bit out it would get diluted out when you fill it.
Mar 29, 2013 / old gas can Thread Starter #3 OP S sal64 Platinum Member Joined Mar 5, 2009 Messages 535 Location ny orange county Tractor jd 2320 jd 990 jd950 Loadstar said: Yea you should be fine doing that. Even if you don't get every little bit out it would get diluted out when you fill it. Click to expand... tu for responce
Mar 30, 2013 / old gas can #4 Soundguy Old Timer Joined Mar 11, 2002 Messages 51,575 Location Central florida Tractor RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC use it. first tank will be higher octane than it left the pump.. no biggie...
