Old fuel tank - how to prep for use?
   / Old fuel tank - how to prep for use? #1
ning
Elite Member
Northern California
Branson 3520h
I recently bought a tractor and don't care for the idea of having to refuel it with 5g jugs, so I found what appears to be a pretty decent fuel tank on craigslist. It's aluminum, about 50g; has a large filler opening that feels like it closes positively, a breather port near the filler, and a valve on the bottom. The construction looks like it's fairly thick aluminum; there's a bit of a dent on the bottom where someone probably dropped it on the valve, and part of the handle of the valve (which looks similar to a water hose bib) is broken off.
It was cheap, so I got it. How to clean it up? It had some diesel in it and looks reasonaly clean; emptied at the seller's. Some of the diesel that came out was gooey probably from water; the tank had been mostly empty for who knows how long.
I picked up a water & particulate filter at TSC. How much pressure is needed to push diesel through a filter? My idea has been to build a stand for the tank and put it up high, and gravity feed to refill my tractor (and occasionally my truck). Can I stick the filter right under the fuel tank, or will I get next to no flow? I can be patient for my occasional refills, but I'm no saint.
CAT 416B (A47477)
CAT 416B (A47477)
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
