Old fluid in Hydraulic rams.
   / Old fluid in Hydraulic rams. #1
Flatbroke
North Central Montana
Massey Ferguson 4610
I have a new tractor, the hydraulics out the back and the front for the loader and the transmission is all the same fluid. My question then is I purchased an old cultivator with a ram on it and probably 20 feet of hose should I drain all the fluid out of any old equipment or just hook it up and go, what do you folks do?:confused3:
GS
   / Old fluid in Hydraulic rams. #2
I would try to drain as much as I could but wouldn't sweat it.
   / Old fluid in Hydraulic rams. #3
I came up with a way to purge oil because I borrow my neighbor's post pounder and he uses JD oil, I use Kubota synthetic. I made a fitting for the return line on the pounder so it would stay open without connecting it to anything. When I attach the pounder I cycle the ram while I put the return line in an empty container. The JD oil is a slightly different color than mine so I can tell when it's all purged. When I return the pounder I do the same thing on his tractor, then pour the purged oil back into the tractor where it belongs.
Since you don't know the history of cultivator, probably wouldn't be a bad idea to purge the oil. Farmers are notorious for using anything they can find as hydraulic oil.
   / Old fluid in Hydraulic rams. #4
In my case I would drain the hoses and un hook the ram and cycle it with the hoses off to force the oil out of it. The snowblower I just picked up had nasty fluid in the turn motor. Not something I am willing to contaminate my hydro system with. CJ
   / Old fluid in Hydraulic rams. #5
Definitely purge it. Since it has hydraulic hoses, remove the QA fittings, and adapt down to an air fitting. Use compressed air to cycle the cylinder. Just turn the air on slow, so it doesn't blow the oil out the other hose everywhere, catching it in a bucket, or oil drain pan.
I've got a 1/2" brass ball valve I have rigged up, and an array of fittings to adapt to about anything, hanging on the wall for things like this.
   / Old fluid in Hydraulic rams. #6
I use QD's and have one fitted with a schrader valve that I can move from one port to the other...a couple of strokes on a bicycle pump moves the rod/gland purging the cylinder...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
UNUSED TELESCOPIC LADDER - 2.5M+2.5M (A54757)
UNUSED TELESCOPIC...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
Informational Lot - Shipping (A55218)
Informational Lot...
