Old Chipper Adjustment
   / Old Chipper Adjustment #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
I bought an old chipper shredder called 'Lil Chipper'. It has an 18hp engine that drives an 18" flywheel connected to rotating blades which do all of the chipping. It handles things within the 3"-5" range. Or so.
The blades are dull and I have sharpened ones that I would like to install. My problem is that I do not have an owners manual, and the company is no longer in business.
The mechanism is very simple. The blades attach to a rotating drum. I do not think that I will have any trouble removing the old blades and installing the new ones. But I do not know how closely I should adjust the blade to the mandrel (? - the thing opposite the blade).
Is there anyone that could give me a guess as to what that spacing should be?
I have absolutely no idea. Lacking any other advise I would probably take a look at what the gap is right now and maybe half the difference. Maybe someone has one of these old chippers, and has a manual of sorts with the specification outlined.
Any help would be appreciated.
Thank you.
   / Old Chipper Adjustment #2
I BELIEVE the adjustment is for different chip sizes,and sharpened knifes have to be readjusted because they are smaller and further away. O n my salsco the range is 1/8 to3/16 .The larger the opening the harder the machine will work,and all the little sticks will pass through,on the other hand,it says the closer ,the slower it will feed.Hope this helped
ALAN
   / Old Chipper Adjustment #3
On my Bearcat it says 1/8 to 1/4 from the anvil.I set it at 1/8.
   / Old Chipper Adjustment #4
I have a Vermeer 620 chipper and the blade adjustment "feeler gauge" is .080". I think the thinner dimension makes for easier chipping. Works good so far.
Sim
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
2025 Mower King SSRC (A50123)
2025 Mower King...
