Old Barn - Restore or Demolish Replace?
   / Old Barn - Restore or Demolish Replace? #1
strum456
Platinum Member
Westmoreland County PA
Fords
I am sad to say that we are at a crossroads with the condition of our century old barn. It is 2 floors, with a barn bridge and a drive in floor and a loft above. It measures 40x50.
The bad:
1. The sills are rotted on 3 sides of 4 sides. This is causing the posts to drop slowly
2. The roof is spreading the walls in the middle
3. All the siding needs replaced
4. The ends are rotted on a lot of the floor joist where the go into the sill on the exterior walls.
5. The foundation is pushed in at one corner due to heaving from the back fill against it.
The good:
1. The majority of the timbers are white oak, and are in good condition
2. The roof is corrugated heavy gauge stainless steel. My grandfather put it on in the 60s. I have no idea where he got it.
3. My dad replaced the sill on 1 side of the barn in the 90s. It is good.
4. The foundation is ok, except for the one corner
I am sure many on this site have been in this situation. I am trying to decide if we should fix it or build something to replace it.
How do we use the barn?
1/3 of the lower section is used as shelter and a feeding area for our beef cattle. We never have more than 20 head at a time. 2/3 of the lower floor is not used for much of anything because it is not accessible for equipment storage and it is too damp to store hay. The upper floor and the loft are used for hay storage (square bales).
One option: Pole Building
Together, my dad and I have built two pole buildings 30x50 ish for our equipment and work areas. Building another pole building would probably be a lot easier for us because we have done it. If we go this route, we would need a shelter for the cows and adequate hay storage space. I think we would be best served to design the building to store round bales and purchase a round baler. Does anyone have suggestions on design or size requirements for this?
Option two: Fix the barn, DIY style.
I have engineering training and plenty of carpentry and mechanical experience. I constructed a 1/2" = 1 foot scale balsa wood model of the barn and I've also done some stress analysis using Inventor (a 3d modeling program). I believe I understand what is happening and I have a plan to correct a lot of the issues. Honestly, the barn scares me a bit. We could literally end up dead if we make a mistake. I think we could fix the barn, but I'm not sure if I want to bet anyone's life on it.
Option three: Hire Amish or other barn restoration specialist:
I don't even know where to start here. I don't suppose the Amish advertise on the internet:confused2:
Sorry for the long post. The barn has been in the family for three generations. I don't want to be the generation that screwed it up for future generations.
   / Old Barn - Restore or Demolish Replace? #2
Save the barn! You'll be sorry if you don't. I've seen many barns, and thought, I would fix that old beauty, poor things sagging in the center. Jack that baby up, beef up the Ridge Beam if it's drooping. I'd like to see a picture of it.
There was a great old barn at our ranch, it's gone now, replaced by an apartment building. Fix it up, your ancestors will smile.
Richard
   / Old Barn - Restore or Demolish Replace? #3
It has been in the family for 3 generations you will regret it if you don't fix it, your last line says it all. Your have the skill and know how to do it.
   / Old Barn - Restore or Demolish Replace? #4
Save & restore! Our old barns are priceless bits of American history and need to be preserved.
   / Old Barn - Restore or Demolish Replace? #5
I agree. I would restore it if possible. I love old barns and hate to see them go.
Chad
   / Old Barn - Restore or Demolish Replace? #6
Restore! In my county, it would cost you 7 to 10 grand to get the permits to build one that size. A restore would save the permit cost and you will still have the family history.
   / Old Barn - Restore or Demolish Replace? #7
Restore it. From a cost perspective it will likely cost more but you will appreciate the history. Priceless.
   / Old Barn - Restore or Demolish Replace? #8
If you really want to, save the barn. In the end when you look back you will be rewarded and I doubt seriously that you will regret it. Usually the issue is money money money. All these things you mention can be addressed. Time and money, sweat.My photo is by no means an example of what you are up against. Maybe just in small inspiration. It will take some cables and come alongs to straighten it up, shore it and brace it, stuff you do over a period of DAYS, bit by bit.
Presumably your material list can be filled by locals with small or large sawmills to supply you with the true dimensional timbers and siding you will want. I hope you go for it.
   / Old Barn - Restore or Demolish Replace? #9
Stainless steel roofing!
Here in New England, people used to regularly move entire buildings and reuse building parts in construction of something in a new location. Timber frames made that reasonably easy to do. As a practical matter, when a building was in the "wrong" place or had out-lived its usefulness, they moved or recycled it. Preserving buildings such as barns is a fairly modern concept in that regard.
For example, the classic New England house, ell, carriage house-barn layout was often built by moving existing buildings into that configuration after it became popular. That is one reason why the roof lines on some of those don't make a lot of sense.
An old bank barn is a beautiful thing if it is in good shape or well preserved. But it's likely not to be as useful or productive as a modern built-to-purpose building no matter how well preserved. A new building, re-using the useful parts in a style that they are compatible with, would also be true to the history of how people actually lived, not just preserving an artifact of those past times.
There is a middle ground solution in recycling and re-purposing. It's not an all or nothing situation. Just food for thought.
   / Old Barn - Restore or Demolish Replace? #10
Call Woodford Bros. Inc. 1-800-653-2276 They did a great job repairing and straightening our barn.
2015 Ford F-150 XL (A44501)
2015 Ford F-150 XL...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
Zero Turn Mower (A44572)
Zero Turn Mower...
2005 CHEVROLET C7500 CAB & CHASSIS (INOPERABLE) (A45046)
2005 CHEVROLET...
Deere 330G (A44501)
Deere 330G (A44501)
John Deere Riding Mower (A44502)
John Deere Riding...
