Old baling twine
   / Old baling twine #1
turkish
I am wanting to do some food plotting on a site with several old cattle feeding sites. There is baling twine under the grass -- lots of it. I assume this stuff will wrap up in a disk or any tillage/planting equipment I want to use. We've tried scraping up with tines of a box blade with only limited success. Is there a better way to get this stuff up and gone?
   / Old baling twine #2
I would try burning it off if possible, that way can open up the dead growth and knock down some of the weeds to point maybe you can get at it better. Otherwise the OLD twine should degrade & rot up in a couple years, then that new poly crap wont.
Mark
   / Old baling twine #4
if you have a chisel of some type , and go in a few inches, 6" or so and see what you can catch and then go cross it the other direction,
I if a bale breaks or have some twine in the field the disk is not a problem but chisels or tined tools will catch it and cause problems keep a utility knife to cut it so one can wad it up,
   / Old baling twine #5
Oh the joy. If it is the poly type you will be getting it up for some time to come. Chisel plow worked best.
Tiller got it up like a charm, but wore through many utility knife blades and busted knuckles (I invented 3 new swear words though, never heard this side of **** before I started working on that piece of ground someone had stacked hay on for the past eon)
   / Old baling twine #6
If there is nothing to damage, like chisel shanks, and possibly rototiller tines a torch on the poly twine,
like on a mower spindle I have burn many a batch of twine off of the spindles.
it just melts it and many times is much easer than trying to knife it off,
   / Old baling twine #7
Wish you would have told me that 10 years ago
   / Old baling twine #8
Torch to get it off, or if you have a lot on there and don't want the heat in the bearings you can use the torch to heat some metal rod to red hot and it will slice right through the poly twine.
For getting the stuff out of the ground I can suggest a multi-point ripper, it will work the ground up and collect a lot of twine, but still be fairly easy to clean off. Rip the soil good, walk over picking up any twine you see, clean the ripper, repeat until you are happy. Then maybe a tiller, but it will still find lots of twine.
Mr. HE:cool:
   / Old baling twine
Thanks for the replies. I guess we'll keep after it with the box blade scarifiers. This stuff is definitely the nylon type stuff -- nigh on unbreakable.
   / Old baling twine #10
Nothing will get more out then a tiller - it is the best bet to actually remove the twine .... but, you will have to clean the tiller of the twine during and after.
As long as you keep the flame away from the axle shaft, using a torch to clean the twine from the tiller blades works just fine - just don't heat the metal, burn the twine.
J and L Cargo Express Shadowmaster Enclosed Trailer (A52128)
J and L Cargo...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
