OK--What's cookin' here
   / OK--What's cookin' here #1
jcmseven
Veteran Member
western NC
JD 2320; 4520
OK--What\'s cookin\' here
Fellow Posters,
So far I have been very happy with my 4520. Only one or two small problems have occurred. First, my air filter restriction light on the dash comes on after 5-10 minutes operation. Not sure why, I can find no reason that it would. I even changed the sensor, still comes on, tractor runs OK. Second, and more importantly, when starting the tractor, two large plumes of smoke, one from the exhaust (normal) and one from either the turbo inlet or exhaust manifold. Actually comes out from underneath the side fairing of the hood. Will stop once warmed up, and tractor runs OK (although there seems to be a continual strong smell of diesel when operating). Is this normal, or could I have a leaky exhaust gasket??? I have checked all obvious hoses without a plain culprit noted. My local dealer is a small dealer, and will keep my machine forever if I take it down, so I want to make sure this is not a normal variant that is seen in this machine before I commit to being without a tractor for three weeks. A little frustrating, as the tractor has only 12 hours on it now, and otherwise runs great.
John M
   / OK--What's cookin' here #2
Re: OK--What\'s cookin\' here
Take it in, light a fire under the dealer , and get it fixed. Something is wrong at both ends of the engine. Almost sounds like both the intake and exhaust are plugged somewhat.
   / OK--What's cookin' here #3
Hi John,
Do you have a dealer near by that works on the skid steers? The engine has been used in the skid steers for years and in my case the skid steer mechanic was able to fix mine faster than the tractor mechanic was. The diesel smell seem normal with these engines. But your leak and air restriction might be the same problem. I would contact the dealer and have him start a "D" tech case when he gets all the information that he needs to work on it then bring it in to him to get it fixed . That should reduce the time he has it by a week or 2.I hope this helps you
Jim
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
