OK, I've screwed up....LS190 NH
   / OK, I've screwed up....LS190 NH #1
gatractorman
Cleveland GA
varies never keep one long enough to post here lol
I removed the injection pump from a LS190 NH for a rebuild of pump without knowing there is no positive way to reinstall pump in gear. They are using a setup much like old Cat stuff with just a taper on the shaft and inside gear with pressure from a nut that holds shaft in the correct place inside gear (no keyway, no splines, shaft could be anywhere inside gear and out of time).
You have probably guessed my question by now, how to get engine on TDC and pump at #1. Thanks
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
Year: 2015 Make: Crane Carrier Co. Model: Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Vehicle Type: Truck (A51692)
Year: 2015 Make...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2024 Bintelli Activ-EV Pulse (A50324)
2024 Bintelli...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
