OK, before I screw up. Where do you add hydraulic fluid on a 22 Max tractor
   / OK, before I screw up. Where do you add hydraulic fluid on a 22 Max tractor #1
jonrjen
Bronze Member
Purchased this a few weeks back preowned and do not have the manuals to the tractor. In the last week the tractor (Max 22 HST) has started leaking at the quick connect connections located at the control lever of the front end loader. I have tightened everything, but the light leaking still persist. If need be I will simply replace the quick connect fitting.
What I need is the information of where do I check the level and add hydraulic fluid? I guess I may as well ask now, what fluid do I add?
I appreciate your assistance greatly.
Jon
   / OK, before I screw up. Where do you add hydraulic fluid on a 22 Max tractor #2
You can find Mahindra operators manual and service manuals online for your tractor. You can also order a hard copy service manual from your dealer. Mahindra manual's are noted for needing serious improvements to both the detailed drawings and language.
Also YouTube has like 5 different videos on specifically changing hydraulic fluid in your specific tractor.
Changing Hydraulic Fluid in the Mahindra Emax 22 Gear Tractor - YouTube
There are a few differences between the Emax22 and the MAX22, just enough to keep me guessing. I don't have a sight window as an example. I did however locate a fill point and dip stick under the rubber mat on the floor tunnel.
Can anyone enlighten me on what kind of fluid/oil to use for the hydraulic system.
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
