Oils, coolant and additives in classic Massey Fergusons
   / Oils, coolant and additives in classic Massey Fergusons #1
DaButcher
TEXAS
2012 JD 5045E 4wd
I know the oils and coolant have been discussed many times on TBN, just thought it would be good to put MF specific information in one place.
  • Coolant: Traditional green antifreeze
  • Engine oil: Rotella T in 15/40
  • Hydraulic oil: ?
  • Steering fluid: ?
  • Diesel fuel additives: 2 stroke oil is good for lubrication and worked well in my former 7.3 F250 and currently in my Ford 1500 diesel
Please chime in with what you recommend and why :scratchchin:
   / Oils, coolant and additives in classic Massey Fergusons #2
I was told to make sure the antifreeze was for diesel engines.
   / Oils, coolant and additives in classic Massey Fergusons #3
Continental gas calls for 10w-30 oil. However, make sure you are buying an oil with a reasonable amount of Zinc dialkydithiophosphate (ZDDP). Basically zinc and phosphate to provide anti wear protection in flat tappet.
If you use a 15-40 in your continental you will be covered as they have sufficient levels of it. However, if you go buy a 10-30 off the shelf that is the current API designation SN, it will not have the amount necessary to protect the motor. You need an API SG, or SL/CF grade. Basically, the grade that contained the necessary ZDDP. A 10-30 motorcycle oil would work fine.
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
