Oil Stick Levels
   / Oil Stick Levels #1
JonSpinosa
Baldwinsville, New York
Have any of you guys noticed how difficult it is to see the hydraulic oil levels on the dipsticks. I changed my front axle oil on my BX2200 to super UDT and cannot read the oil level on the stick. The viscosity and color of the super UDT makes it impossible to read. It drives me nuts to pull the dipstick out several times and still can't read it. Have any of you guys solved this problem? I am thinkink about painting it or roughing it up with some sand paper!! Any thoughts?
Jon
   / Oil Stick Levels #2
Jon, I think everyone has the same problem, and it's been discussed at length in other threads, but I'm not sure where to find them. Some of the solutions (if you can call them that) are:
(1) to dip the stick in talcum power first, then in the oil (don't like that one personally even though the powder supposedly won't hurt anything),
(2) bright lights,
(3) blot it on a clean paper towel when you take the stick out to see where the towel is wet,
and now I've forgotten the others; just use the bright light and/or blot it on a rag myself.
Bird
   / Oil Stick Levels #3
Jon,
Take your vise grips and pinch the dip stick. This should make nice little dimpples to which the oil should be easier to see therein.
Winnipeg, Manitoba
2001 BX2200 (23 hrs) All Kubota FEL,Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
   / Oil Stick Levels #4
How about changing the color with a permanent magic marker, say to black? I haven't tried it yet, but it might work.
   / Oil Stick Levels
After looking at the hydraulic oil dipstick(which is flat) and the axle oil dipstick(which is round) it became obvious to me that the geometry of the dipstick helps to determine how easy the dipstick can be read. Therefore, I filed the round dipstick so it is flat on one side. It worked!! Before the dipstick was impossible to read. Don't get me wrong, both dipsticks are difficult to read, however, at least I can read the axle oil dipstick!!!! I hope this may help you guys also.
Also, thanks for some of the suggestions. If there are more, please send them along.
Jon
   / Oil Stick Levels #6
Mine are both round./w3tcompact/icons/frown.gif
Bird
Forerunner 10-16.5 N.H.S Tires and Rims (A50322)
Forerunner 10-16.5...
2014 Wabash Tanker Trailer (TITLE) (A50774)
2014 Wabash Tanker...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
