Oil Smoke??
   / Oil Smoke?? #1
ironpen
Montgomery, Alabama
tn75s, tc33d, mc35, gt65, 6640, 3010s, TS110, TS115, TN70, Massey 5470, Kubota F2690
My mc 35 (front deck commercial mower) has a 35 hp Shibaura diesel engine. 1300 hours. Runs good....but yesterday I noticed some white/blue smoke coming out under mid chassis. It looks like there is a vent tube from the valve cover that goes down there. I have never noticed it before. It does use about 1/3 qt. oil about every 10 hours, but I always top it off and check before each use. The oil usage is a longstanding occurrence. Like I said it's running fine. I use Delo 15-40 and change the oil and filter each season...about every 75 hours. Do I need to hit the panic button?? Any ideas if this is a normal finding. When I noticed it the sun was low on the horizon and I got off to pick up a bottle. I at first thought maybe it was a small antifreeze leak, but it was not. Any thoughts from anyone?? I did recently change the water pump, but it appears to be working fine and temps are normal. No antifreeze usage. TIA
   / Oil Smoke?? #3
I wouldn't hit the panic button yet if it is running fine.
It has probably always blown a little bit of smoke out the vent tube, you just haven't noticed it till the lighting/angle was just right.
   / Oil Smoke??
Thanks to you both. It wasn't under any load when I noticed it. It is not blowing any smoke out of the exhaust at all. Very interesting article BTW.
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
