Oil & Fuel Oil Seal on TC55DA Front Axle.
   / Oil Seal on TC55DA Front Axle. #1
Osconda
Texas, Williamson County (aka Texas Hill Country)
New Holland TC55DA, delivered 05/25/2005
Hello Folks,
I have a very slow leak on the front left axle. Enough to accumulate a lot of dirt on the wheel between washings. I'm going to replace the seal but wanted to get some idea of what this job entailed.
Since it's front-wheel assist it looks like I have to pull the axle. Not sure though. I haven't taken anything off yet.
Anybody done this kind of repair before? Any advice? I should have everything I need in the shop except the seal ($55) which I haven't purchased yet.
   / Oil Seal on TC55DA Front Axle. #2
Hello Folks,
If it is the axle shaft seal leaking, it's quite straightforward. Have a tube of anaerobic gasket eliminator available to seal the reduction gear cover. Even the swivel seals aren't difficult. I routinely replace either on tractors on-site. Ford 10 and 20 series compacts and all the later NH compacts use the same designs, if not the same parts.
   / Oil Seal on TC55DA Front Axle. #3
Hi Rick B, When you say routine, are we talking 2 to 4 hours with the seal? Any special tools required?
Thanks, Coolhand
   / Oil Seal on TC55DA Front Axle. #4
A properly sized seal driver and a well stocked toolbox. Less than 2 hours for a first timer, less than an hour with practice.
   / Oil Seal on TC55DA Front Axle. #5
RickB - Thanks for the reply. Seal is on the way from Messicks. I have the seal driver - I looked at the assembly closely, seems pretty straightforward. Appreciate the info
Coolhand
2014 FORD F-550 ROUSTABOUT(INOPERABLE) (A52472)
2014 FORD F-550...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
