Oil recommendations for an old 1970 Allis Chalmers 615 Hoe Diesel
   / Oil recommendations for an old 1970 Allis Chalmers 615 Hoe Diesel #1
zippy64
Allis Chalmers 615 backhoe D2200 I think
Manual calls for AM303 for Torque tube/Power steering. AM303 for the Shuttle clutch. 80EP for the Transmission. SAE20-20 for the Final drive's. Was thinking SAE30 for engine? Not sure what Hydraulic oil to use? Tractor is is in northern NY but I only run it above 50 degrees. Thank you..
   / Oil recommendations for an old 1970 Allis Chalmers 615 Hoe Diesel #2
A good known brand of transmission hydraulic fluid would be acceptable in anything, but the engine. 30wt for the engine would work fine.The transmission could use 80EP or trans/hydraulic.
Thanks for making me research the 303 though as here is an article to the origins of 303 that I wasn't aware:
   / Oil recommendations for an old 1970 Allis Chalmers 615 Hoe Diesel #3
what type engine oil has the machine been running?
I think I used 15-40 for the engine. It gets used 0-15 hours a year. The only reservoir I have had to add to is the hydraulics which was AM303. Just wondering if someone has a 70's tractor and if I should be concerned about the newer additives in most oils. Some additives are not good for yellow metals and old seals from what i read. This tractor has 5 or 6 different fill points and specs out 4 different oils. The two most important to me are the cross reference to a newer oil for AM303 and 80ep gear oil.
   / Oil recommendations for an old 1970 Allis Chalmers 615 Hoe Diesel #5
The engine is Being treated well with 15w40.
I wouldn’t worry about the newer oils as they probably protect more than harm.
My old 550 Ford and KD Forklift with a 78 Ford power train work well with the new oils.
   / Oil recommendations for an old 1970 Allis Chalmers 615 Hoe Diesel #6
maybe stick w/conventional (diesel rated) rather than full synthetic (engine & trans) to avoid taking out old seals. some may disagree on that but conventional alone will do you just fine.
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
Pallet Fees (A50775)
RIGID 1224 HAMMER CHUCK MACHINE (A53843)
RIGID 1224 HAMMER...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
