northpolefolks
Bronze Member
- Joined
- Jan 8, 2012
- Messages
- 83
I received by U5020 last week. I put 3 hours on it so far and yesterday went into the garage to check the fluids ect before taking it out to move snow and noticed a puddle of oil under it. I traced the leak and found that oil looks to be leaking from the oil pressure relief valve. It is also spraying up the engine onto the block plugs.
Enough oil has leaked that it covered the side of the engine, oil pan, all the hoses on the right side of the engine as well as a portion of the frame on that side.
The oil pressure looked fine the last time I had started it. Not too full.
Any thoughts on why it may be pushing oil out the relief valve?
The dealer is showing up this morning to take the tractor to his shop to look at it.
By the way, other that this issue, the tractor thus far is great.
