Oil Pressure Problem L4240
   / Oil Pressure Problem L4240 #1
pmhowe
North west North Carolina
Kioti CK2610
I was out working with my L4240 today when I noticed the oil pressure lamp was on. I immediately stopped the tractor. Oil level is fine. Oil is nice and clean. The tractor has 112 hours on it. I changed oil and filters at 50 hours, just recently pulled 100 hour maintenance. I let the tractor rest while I had lunch and read the manual. Found location of pressure switch, checked to make sure wires were not loose. Restarted tractor, oil pressure went out briefly, then came on again. Oil light stays on at both idle and 2000 rpm. I壇 like your advice.
First thought is that the sending switch has malfunctioned. Is this a common problem with the L4240 series? Has anyone put an oil pressure gauge on this model tractor? I壇 like to do that anyway, as I am not fond of idiot lights.
Thanks for your help.
   / Oil Pressure Problem L4240 #2
I have 800+ hours on my L4240 and never had that happen.With that low of hours a call to the dealer would be my recommendation.
   / Oil Pressure Problem L4240 #3
My advise would be get a manual test gauge in the sending unit ASAP and not run the tractor until you determine the tractor does have oil pressure. The dealer would probably loan you a tester.
Again don't be running the engine until it is confirmed the tractor has oil pressure, please.
   / Oil Pressure Problem L4240 #4
Are you still within warranty?
   / Oil Pressure Problem L4240 #6
If you are NOT under warranty,,
replace the oil switch and see if that cures it, there 20 bucks or so.
It could be dirty inside at the end, if that doesn't do it, throw a gauge on it.
Please let us know your results.
As also stated, don't run it until the problem is resolved.
My tractor is still under warranty. Yesterday, I drove to the dealer and purchased a new oil pressure sending switch. This morning, I installed it. It was a ten minute job. Problem solved: It was a sending switch that had gone bad. Dealer says to return old switch, for refund. Thanks all, for your comments.
   / Oil Pressure Problem L4240 #9
Someone once posted, why do I need all those gauges you have warning lights.
I don't know? because they look nice?
Glad you solved the problem.
   / Oil Pressure Problem L4240 #10
Hey, WaxMan...I think I seen that movie....lol
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
CONTACT INFO (A53084)
