Oil Pressure Light Illumination Time
   / Oil Pressure Light Illumination Time #1
Spanky100
NE Texas, NE Tennessee, and SE MI and SW OH
Current Kioti CK27HST and Cub Cadet 1810. Previous NH1510 Hydro, AC D14, Oliver 1355?, and JD 314 Lawn Tractor
Observation after the initial engine start up after my first engine oil and filter change. Temperature 45 F with Kioti oil filter and 10W-40 CJ4 engine oil.
The engine oil pressure light stayed illiminated for an estimated 3 to 4 seconds after the first start following the oil and filter change. Re-starts afterwards the light seems to go out in about 1 second. Suspect this is normal as the system has to re-prime the pump, oil galleries, and fill new oil filter before the oil pressure builds high enough to make the pressure switch so the oil pressure light goes off. In other applications, that have a vertical mounted filter, I usually fill the new filter befor re-installing.
Do these times seem normal after a engine oil and filter change?
thanks
   / Oil Pressure Light Illumination Time #2
Yes mine does the same, more so if below 30 and not started in a few days.
   / Oil Pressure Light Illumination Time #3
Normal working. The oil pressure sending unit is at rear of engine at farthest place from pump. Takes a while for oil, when starting up after oil change. Especially when cold.
JDL and LaVoie
Thanks for information. Glad to confirm that this is normal.
Thanks again.
Spanky
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A52576)
1968 CHEVROLET C10...
