Oil & Fuel Oil pressure light flickering
   / Oil pressure light flickering #1
509diesel
WA
TYM T233
Hi guys,
I recently got a T233 new and it has about 13 hours on it, but today the oil pressure light started to flicker. This happens even at idle, I was curious if anyone knew why this might happen. The dealer is closed till Monday so I will give them a call then, but looking for ideas in the meantime.
I checked the oil level and it is fine and the tractor seems to idle fine, so I am thinking maybe it is an issue with the sensor?
   / Oil pressure light flickering #2
I removed the sending unit and hooked up a oil pressure gauge. Everthing on mine was fine . It showed good pressure at idle and while running at more RPM's. The sending unit had recieved a good dose of cleanig fluid and it had gone bad. It is nice to see actual numbers. Removed the actual gauge and replaced the sending unit for under 20 dollars.
   / Oil pressure light flickering #3
2458n,
I like that idea, I too want to see the actual pressure numbers so they can be monitored. I may take it one step further, if there's enough room and sending unit port is in a protected location. I'd like to install a "T" so the warning light sending unit and a pressure gauge can be installed. Best of both, a warning light to get your attention and a pressure gauge to see what the oil pressure is.
Thanks!
Look like the issue was with the sender. Seeing about 50 PSI on a gauge. The dealer had to order one so it should be here tomorrow.
2015 CATERPILLAR 259 SKID STEER (A51246)
2015 CATERPILLAR...
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
Duetz Power Unit (A50120)
Duetz Power Unit...
