mcycle
Oil pan seems to be leaking all the way around the pan. Oil is not running out, but leaking enough that it drips two or three drops on the floor after each use. Can't find any oil above the oil pan, or any at the front crankshaft seal. It all seems to be coming from around the oil pan. I've tried to tighten the pan bolts, and they are tight. Since the tractor is new, all the pan bolts are covered & sealed with gray paint. I have not tried to break the bolts loose, to loosen the paint, and then retighten them. Has anyone else had a problem with the oil pan leaking ?
Thanks !!
Thanks !!
