clemsonfor
Super Member
I have been useing my ym2000 a good bit this weekend. Today I had bushhogged a few hours and tdrove it down into the woods to cut a tree out of the road. When I got to the tree I brought it down to an idle and was going to leave it running. When I got to about 1000 Rpms or lower the light lit up. If I increased just slightly it went away. I thought the wire might be the issue it was a tad loose. I did what I needed to do. Went back up to house. Pulled the screw off and cleaned it and the connector till shiny. This made it go off when i started it up (although the last few times after I noticed when I started it it would take like 30 seconds at that rpm till it came on for whatever reason. This is on it warm and only been off 10 mins or so , so not enough time to cool down). So I left the tractor to idle at a tad under 1000 or so and did a few things. It states off for 5 or 10 mins at that rpm. Then I looked over and it was dim or just lit up I can't remember. Increase it slightly it went off. Now here is the difference, idle it way down and it went out too. The light was coming on at only maybe 800rpm lower or higher it was off. The place it lights up is the 5kmh notch which is below the 1000 mark on the top side. I guess it would be around 750 to 800 rpm.
Never has this light come on before. There is no difference in the way the motor sounds. I'm wondering if I have a bad sensor or maybe it got some trash in it? I didn't have time before I had to leave to pull it out and try to clean it or anything. I just plan to buy a new one and see if that fixes it. I don't have an external cause to try to see pressure. Maybe this will make me buy a tool for this.
California do you have a part number from a Nissan/Datsun that you found for one in all your playing around with these? I didn't some quick look ups a bit ago on some 70s nissan applications and didn't find anything that looked like it on advanced auto.
Other than this the tractor was flawless this weekend. I disked about an acre and a half of foodplots and bush hogged several acres.
