Oil Light on TT60A
   / Oil Light on TT60A #1
jbos3333
NH TT60A/IH 234/Ford 3000 Industrial
Hi all,
I have a TT60A that the oil "idiot" light has recently come on. I hooked up a gauge and it shows 54 psi when semi-warm at idle rpm. I also bought a new pressure switch and installed it, hoping that would be the solution (cheap solution- the pressure switch is less than $5 from dealer).
Well, there was no change in the idiot light. So, with the oil pressure gauge installed, I ran the machine and grounded the wire through a test light. The idiot light got brighter. I also plugged in a pressure switch and grounded it, the light got brighter in that case as well.
Any ideas? I hate to spend $300 on a new instrument cluster, but if that is the fix, i will.
Thanks,
Jay
I will see if I can trace the wire back. Not sure if it goes directly to the instrument cluster connection or not.
2017 John Deere Gator TS Utility Cart (A50322)
2017 John Deere...
2006 Kubota L5030D 50HP Front Loader Utility Tractor (A50322)
2006 Kubota L5030D...
2018 Honda CR-V LX SUV (A50324)
2018 Honda CR-V LX...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Electric Mobility Scooter (A51694)
Electric Mobility...
Swict 66" Skidloader Bucket (A50774)
Swict 66"...
