Gizzard
My first time here, hope to find an answer to an oil leak problem on a 2012 Jinma 284, purchase last year. The tractor work fine until a few weeks ago where i noticed oil spraying on my left foot it was bouncing of the side of the FEL brace. I stop the tractor and look around could not notice where it came from so i started the engine again and the engine oil started to ooze out of the oil filter all around the rim. First tough it was plug or loose, so i removed and replace it and reset the oil level, after that the engine did not start it just gave me a loud clunk. I removed the valve cover to inspect, nothing found. loosen the injectors and pump and turn the engine suspecting a cylinder full of oil or fuel if that make sense, and button up everything started the engine and it smoke heavily for a bit and started to puur like a kitten just fine. Now checking the oil level, i can see it creep up a bit after every use, i do not smell or feel antifreeze on the oil dipstick, the hydraulic oil was low so i replenish it. I am at the point where every time i use the tractor i check the oil level and hydro oil level to see if one dropping and the other rising. I suspect hydraulic oil is making its way into the engine, is this possible the FEL and 3 PT work fine by the way.
