Oil leak
   / Oil leak #1
pruntyc
Platinum Member
MS
John Deere 4110 HST
This time I know I have a problem, my YM1700 has an oil leak. I've put around 40 hours on it, and it hasn't gotten better or worse. I just can't figure out where its coming from. I seems to be comeing from where the Transmission bolts to the engine. I see it comeing from right behind the fuel filter. It just starts getting wet there and more as it goes down. It don't look like its comeing from the valve cover or the oil line that passes around the cover, as they are both dry. Has anyone else ever had this problem or any idea where it might be comeing from?? Its not a real bad leak, but enough the oil goes down on the dip stick about 1/4 inch in around 4 to 5 hours of use. So I would like to find it and try to fix it, before it gets worse. Thanks /forums/images/graemlins/confused.gif
   / Oil leak #2
Is there any way to get us a picture? That would help me immensely.
Buck
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
2009 John Deere 1810E Scraper Pan (A53342)
2009 John Deere...
