aesmith
Hi,
I just had to cut the shaft to length for our topper, and while I was in a PTO mood I checked and cleaned the shaft for the snowblower as well. What struck we was how sticky the inner section is with grease on it. It would be really easy to pick up grit and if that gets into the outer tube it would be a real PITA to clean out. So I was wondering if it would be OK to use gear oil instead of grease for the tubing, that way it would be easy to wipe down when I'm handling it, and if I got crud into the outer tube it would be easier to flush it out.
Any thought?
Thanks, Tony S
Any thought?
Thanks, Tony S
