Oil in air filter
   / Oil in air filter #1
MuncyBob
Platinum Member
N Central PA
PT 422
I'm noticing a small amount of oil on the underside of the air filter and a bit around the rim of the carb. It's been this way for awhile but seems the amount showing up is increasing a bit. What's going on?
   / Oil in air filter #3
Hmmm,, just guessing that the engine has a Positive Crankcase Ventilation (PCV) valve and system??? If so, it's plumbing into the airbox which creates a vacummn in the engine drawing off any blowby gases. That creates an oily condition in the airbox and/or carb if the engine has significant blowby. Blowby is usually caused by combustion pressure seeping past the piston rings and into the crankcase. No big deal unless it's so bad that it plugs the air filter. I've saw engines with puddles of oil in the bottom of the airbox and still operate fine.
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
