Oil help please?
   / Oil help please? #1
Attatood
Edmonton, AB Canada
Case 1835
I have recently purchased a Case 1835 Skid Steer at an auction. I have operated them before but have never owned one or had to look after the maintenance. When I bought the machine, the hydraulic reservoir was very low so I topped it up with hydraulic fluid and everything runs well. However, I just bought the owners manual online and it states that the reservoir should be filled with motor oil and an additive from Case. Is there a difference or will the machine be fine with hydraulic oil? Any help is appreciated because I don't know much about these systems.
Thanks.:confused:
   / Oil help please? #2
G'day over here case usually spec CASE TCH oil for most of their equip as it will do trans, hyd and all in one units if you have used a good quality 68 hyd oil i cant see that you would be causing any probs with it best of luck with i and have some fun:)
Jon
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
