oil from breather vent tube?
   / oil from breather vent tube? #1
mathey
Platinum Member
MD
NH TC33D
My CK20 has about 47 hours on it. Yesterday after a full day of mowing (hot day - 95 deg), I noticed a few drips of oil on the garage floor. Closer inspection revealed it came from the breather vent tube attached to the top of the valve cover.
Is this normal or something I should be worried about?
   / oil from breather vent tube? #2
I would not be worried about this as a certain amount of crank case blow by and venting is expected especially as the engine is going through break-in. I would recommend that you change the oil and filter at 50 hours if your owner's manual does not already specify this. If this symptom continues to worsen, then I would have the dealer look at it. Another 50 hours of run time should give an idea as to what is the trend.
</font><font color="blue" class="small">( I would recommend that you change the oil and filter at 50 )</font>
yes, i'm scheduled to do that this week...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
2000 Chevy 3500 Wrecker Truck (A52384)
2000 Chevy 3500...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
