3-Point Hitch Oil For Hydraulics
   / Oil For Hydraulics #1
st2040
edgewood,illinois
satoh st2040 & mt372 & 1968 international Cub & 1937 Short frame B john deere
If anyone could help me i would appreciate it - I have an ST 2040 satoh and would like to know what oil to put in the hydraulics,I have a neighbor who has a small compact massey that uses 80-90wt. for hydraulic & transmission.
   / Oil For Hydraulics #2
You should be fine to use any "universal tractor fluid" that meets JD303 or IH Hy-tran, I expect. ATF, gear oil, or even engine oil would all probably work, with varying tradeoffs. The tractor hydraulic fluid is probably best, though.
In your earlier post about your machine, there were some tips and questions that may help us give better advice. What did you find when you got the engine number, looked for extra dipsticks, fill plug bolts, or anything else that may help?
   / Oil For Hydraulics #3
Just about any universal hydraulic oil will work if you are draining and replacing all of it. NOT too many tractors use 90 W oil for hydraulics as it is just too thick. Most hydraulic oils are around 10W. I could find any recommendations for my Yanmar but since the made John Deeres at that time, I just went for the oil recommended for their compact tractors but I don see a lot of difference in it. When I asked my LS dealer about what he put in the hydraulic at his shop, he said just use any universal oil and it will be ok and that was on a new tractor.
2019 ISUSZU NPR BOX TRUCK (A54607)
2019 ISUSZU NPR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2017 Ram 5500 Crew Cab Reading Service Truck (A52377)
2017 Ram 5500 Crew...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
flooring (A53424)
flooring (A53424)
