oil filter number for the model 1532 3 cyl diesel
   / oil filter number for the model 1532 3 cyl diesel #1
digger15
mf model 1532 hydrostatic
I just bought a mf model 1532 3 cyl diesel hydrostatic tractor. Soon i will need to buy oil filters and oil, need to know the oil filter make and numbers and the proper weight of oil for the diesel. Will use this primairly in the summer to cut grass. 10w30 / 30 weight Amsoil diesel?
Thank you in advance.
T
   / oil filter number for the model 1532 3 cyl diesel #2
Wix 51360 oil filter. Check the manual for the proper viscosity oil to use in it. I would guess, based on Dad's L4740 manual recommendation that it will spec a 10W30. If you want to use Amsoil diesel oil, it will be good, but you can pick up Rotella T synthetic 5W40 much cheaper and it will be a fine oil to use as well.
Thank you for the tip on the Wix filter number (51360). I'm an Amsoil dealer and the 10w30/30 would be great to use in this 3 cyl diesel.
9202 (A50322)
9202 (A50322)
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
