RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,885
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I just did the 50 hour engine oil change on the B2601. Wonder if anyone has used an oil extractor to know which side of the pan the extractor empties?
I should have done it, e.g. used oil extractor to figure this out. Then I'd only unscrew the plug that it does not empty next change @ 250 hours. Will do it then.
Had troubles with getting the right side plug back in until I dislodged the copper gasket. Then found that side leaking a day later. Tightened it some more.
