The other day while emptying some used oil into my storage bin I found a copper washer.....after the old memory cells started to click....I had changed the oil on my Kubota a week before. The washer must have come off when I dropped it into the drain pan....I put the plug back in without checking as I had never done this before.
My question....I've run the tractor for a week on and off and there is no oil leaking. I didn't know if without the washer the oil pan might crack due to the tightening pressure? I could use the finger-in-the-drainplug hole for a minute while I slipped the washer on. I will do this is any of you would do the same or just let it go until the next oil change. Thank you for any opinions.
