Oil drain plug on TC25/29D and NH - bolt only?
   / Oil drain plug on TC25/29D and NH - bolt only? #1
cdcole
Wisconsin
TC25D
Again - while adjusting loader pressure and such. I was inspecting for leaks, etc.. Found a very small amount of oil around the drain plug and it prompted me to ask this question. Does the drain plug consist of just the bolt - or a bolt and washer or a bolt, washer and rubber gasket. Just thought I would double check this because when I drained it - the bolt fell into the drain tub - then I dumped the drain tub out after removing the bolt. I could sift through the 5 gal. bucket to make sure that there was no more parts in there other than the bolt I pulled out but it would be messy. Could someone please take a look for me? - that is look at your NH unit.
Thanks,
Cliff in Wisconsin
   / Oil drain plug on TC25/29D and NH - bolt only? #2
cdcole,
The drain plug on my rig has only a copper washer. I would have preferred a washer with a rubber o-ring like my truck has because sometimes if everything isn't just right it weeps a little.
tinner
   / Oil drain plug on TC25/29D and NH - bolt only? #3
Not that anybody does it, but I think those copper washers are designed to be replaced each time you change the oil. Copper is a soft metal that crushes and that is what provides the seal.
   / Oil drain plug on TC25/29D and NH - bolt only? #4
I have always used nylon or plastic washers on my oil pans. I haven't bought any for years, because I made a couple of dozen at the last machine shop that I worked at. You should be able to find them at AutoZone or PepBoys.
Thx Gents.
I tightened it a little more and it sealed but plan to put washer on at next change (copper or nylon)
Cliff
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
