Oil compatibility chart?
   / Oil compatibility chart? #1
Dadsgreenpsd
Bronze Member
Maine
Jinma 254, and JCB 1550B
I have a JCB 1550, and a Jinma 254. The hydraulics on both is AW, but the JCB takes 10w Hyd for the brakes, 10W engine oil for the torque convertor, TDH for the transmission, 80-90 for the swing, and probably some others i have forgotten about. Anyway, i have several pails of fluid around, and was wondering if any of them could be used in place of plain AW, or mixed with it. I have searched for oil charts online, but i am not really interested in the shear strength or flash point :D
Thanks!
   / Oil compatibility chart? #2
Not to sure what type of chart your looking for. Your best bet is to check the fluid specification sheet for the fluid and see what it capable of doing and what applications it should be used for.
A good high quality universal tractor fluid should handle most applications that call for light weight/hydraulic fluids. Use a good high quality UTF, or a slightly thicker UTF with tackifier additive and for special applications calling for a 303 fluid.
As for gear oil, do not use a thiner viscosity fluid in it's place. If it calls for a heavy weight 80 to 90 weight gear oil use just that.
Whatever you decide to use stick with it. It is never a good idea to mix different manufacturer's lubricants. Different additive packages in the oils can end up canceling out any benifit's that they may provide and can sometimes cause seperation of the additives. If you pick a different fluid to go with, drain the whole system and refill with one type fluid and then use that same fluid to top off the system when needed.
As for shear strength and flash point you should be concerned. The specifications of the fluids you choose are very important. Cheap fluids are just that, cheap and have very small additive packages, low quality base oils and lower specifications. High quality oils are made with ultra refined base stocks, superior additive packages which make for high specifications and extended drain intervals and decreased wear. A good lubricant manufacturer should also provide used oil analysis (UOA) for free for their products.
UOA itself can end up saving you alot of money in the long run by detecting problems before they become critical. They are great for finding leaking head gaskets, fuel dilution, water contamination, wear metals (indicating something is about to break) and other fluid contamination that could cause a problem in the short term future.
Best advice is to buy the best quality lubricants you can afford. The better ones cost more at the start but are worth the investment. Increased drain intervals alone can recover the initial cost difference. Reduced break down frequency is also a added bonus along with better cold temp operation characteristics.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2015 Jeep Compass Latitude SUV (A53424)
2015 Jeep Compass...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
