Oil & Fuel oil comming out of the breather
   / oil comming out of the breather #1
dfh
Rochester, Washington
Kubota B-7100
I have a KUBOTA B-7100 aproximately 1980 vintage. i have a problem with it spewing out oil from the breather tube when it is running about half throttle. this tractor has about 2200hrs on the motor. it starts and runs fine and does smoke a bit when it first starts.? Oil was changed aprox 6 hrs ago.
Is it time for a rebuild or is there something else going on?
Also i have a slow working loader operation even at proper op speeds. I was told it may be a pressure adjustment.? I did have the pump looked at and it is in good shape. The loader is a KUB219
Any suggestions?
DFH
   / oil comming out of the breather #3
Reads like wet stacking.
Has it been run for a long time with no load?
71066 (A49346)
71066 (A49346)
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
John Deere 702 Hay Rake (A50515)
John Deere 702 Hay...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
