oil coming out of breather
   / oil coming out of breather #1
Russell Howard
Cumbria UK
New Holland 7635
Hi
I have a New Holland 7635 and it is spitting a lot of oil out of the breather when under load, don't think it is the piston rings as low hours and well looked after.
Could I have the wrong oil in ? currently using 10w30
thanks
Russell
   / oil coming out of breather #2
Most people would run 15w 40 in that series engine, but many Japanese diesels run 10w 30 and don't have problems. Is this what you have always used without problem until now? Is the oil level high, and possibly thinned out with fuel or hydraulic fluid? The steering and hydraulic pumps are engine driven, so either could possibly transfer fluid to crankcase. Steering would run dry quickly as it holds only a quart or two, but hydraulic, injection, or fuel lift pumps could be a factor.
   / oil coming out of breather #3
Hi
thanks
Russell
Assuming you aren't overfilled with oil, worn rings or a burned/cracked piston crown are the usual causes of serious blowby.
Thanks guys
oil level seems ok and there no real 'blow' from the breather just oil !
I think we used to run 15w40 and our supplier changed it to 10w30 a while back which could coincide with the problem.
I'll change to 15w40 and see if that cures it.
   / oil coming out of breather #5
You have problems that an oil change won't fix. Maybe crankcase breather plugged? Jmho
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
Electric Forklift Pallet (A50322)
Electric Forklift...
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
