Oil coming from breather tube
   / Oil coming from breather tube #1
vadasz
long 445
I have a Long 445 farm tractor 3 cylinder diesel It blows oil spray down the crancase vent tube
   / Oil coming from breather tube #2
Sounds like you have some worn rings, pressureizing your crank case and causing oil to blow out of the breather tube.
If you have the time and money rering it and your good for another 20 years if not you can probly run it like that for quite a while longer no harm done.
Thanks for your info.I hope the rings can be changed without pulling the engine.
   / Oil coming from breather tube #5
I'm not familiar with your engine, but on our in-line 6 Cyl Hercules diesel's from the 60's / 70's there is a filter where the vent tube attaches to the valve cover. The filters wearout over time and oil will spray like you are talking about. A new filter stops it.
So, you might want to check and see if yours may have had a filter. The filter material is a woven nylon, like a 3M Scotch Brite scrub pab.
   / Oil coming from breather tube #6
Those are on most older auto engines as well, there not designed to do aything but kind of catch vapor and knock splashes back, its possible that yours just is replaced as it soaks it all up then becomes saturated then flows out.
There should be no pressure in the oil pan, to a degree. Some will obviously be there as its an older engine, but should not feel like a mini-exhaust pipe! An oil pan is like a hurricane of oil when the engine is runninng with the cranks rotating around in it.
   / Oil coming from breather tube #7
Either you have excessive blow by (worn rings, cracked piston) or the crankcase vent system could be clogged. Check the latter first.
   / Oil coming from breather tube #8
i had oil coming from my breather and found out i blew a head gasket but know it smokes bad with fuel smoke.
   / Oil coming from breather tube #9
nice post on a thread thats over a year old? Have you been clicking the links at the bottom again?
   / Oil coming from breather tube #10
Oil coming out from tractor engine breather pipe why????
2006 Ford F-150 XLT (A44501)
2006 Ford F-150...
HUSKY TOOLBOX (A45333)
2017 GMC Sierra Pickup Truck, VIN # 1GTR1MEC6HZ115515 (A44391)
2017 GMC Sierra...
2016 Toyota Camry Sedan (A42744)
2016 Toyota Camry...
2017 Ferris Soft Ride Z2 52in Stand-On Mower (A42744)
2017 Ferris Soft...
Zero Turn Mower (A44572)
Zero Turn Mower...
