Oil Checking on GR2100
   / Oil Checking on GR2100 #1
Kevin56
Kubota GR2100
I found it on left side of engine under the air filter. It is not listed in my owner's manual.
Hello, I have a Kubota GR2100 from November 2006. When I read the owner's manual for how to check engine oil, it just says "Add new oil to the presribed level at the oil port if necessary." There's no dipstick on this diesel and I can't find any info on what is the "prescribed level". Can a GR2100 owner please clarify?
   / Oil Checking on GR2100 #2
When you say "I found it" does that mean you've already solved the problem?
I'm not much of a mechanic, but the dipstick on my GR2100 is about 3-4 inches to the rear of what is, I believe, the white plastic fuel filter on the left hand side of the engine (as you sit on the machine).
I believe the stick is marked, as any dipstick is usually marked. The dipstick handle is pretty small & is painted to match the engine, so is not easy to spot. Hope this helps.
Yes, I did resolve the problem by finding it. Thanks for getting back to me.
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
