Oil change yanmar 1610D
   / Oil change yanmar 1610D #1
papayanmar
Shady Cov, or
Yanmar 1610d
Simple question... how many quarts of oil in yanmar 1610D engine?
Gonna use Delo 400 15-40 unless told not to.
Time to do some maintance!
Thanks in advance,
Papa
   / Oil change yanmar 1610D #2
I can't tell you exactly but somewhere between 4 and 5 quarts. Put in 4, circulate, let settle and fill till you get to full mark on dipstick.
   / Oil change yanmar 1610D #3
First time I changed oil in my YM186D I measured the quantity and wrote it on the lip where the hood rests on the cowl. As I recall it was 3 quarts 12 ounces. I have no idea if your slightly larger engine takes this quantity but this would be a good starting point for filling it. Then look at the dipstick and add if needed. You might post back here on what you find - the information will be useful to someone.
I thought of the drain and measure method, but wanted a base line to start with. I bought a gallon jug, so I'll start there. I will post the results when finished. My only worry is that the dip stick shows an over filled condition. I hope that doesn't mean a leaking hydraulic cylinder!
Thanks to all!
Hydraulic pump... not cylinder duh.
   / Oil change yanmar 1610D #6
I should have clarified that I measured what I put in after a drain and filter change - didn't measure what came out. I used this one-quart measuring cup/funnel (with tube removed). It has a shutoff and graduations on the side.
Ok, the oil change went well. 3 1/2 quarts it is.
The fuel filter change didn't go quite so well. The act was simple enough, but I didn't bleed the system before driving off. Yep, got about as far away from the shop as I could get before it quit. Bled the system, and it started right up. Lesson learned.
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
2012 Killbros 110 Grain Cart (A50514)
2012 Killbros 110...
2023 TAKEUCHI TL10V-2 SKID STEER (A51242)
2023 TAKEUCHI...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
