Oil Change interval
/ Oil Change interval #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
3 weeks ago I changed the oil and it's due again on the L39.
50 hours come too quick. I'm not running the l39 through a dusty field at max rpm full load so what does everyone think about 75 or 100 hour oil changes?
My excavator service interval is 200 hours. What is the difference in a TLB's operation and service interval?
/ Oil Change interval #2
The best way to extend your oil change interval safely is to start doing UOA's (used oil analysis). With a UOA program you only change the oil when it needs to be changed.
/ Oil Change interval #4
The owners manual on my L2800 and my previous B7500 had 100hr oil changes.
/ Oil Change interval #6
Our L-39 calls for 100 hour engine oil changes and that's what we've been giving it these last 600 hours, all Amsoil 10W-40 Full Syntheitc.
Been using Amsoil Synthetic Hydraulic Fluid on the GST tranny every 400 hrs to.
/ Oil Change interval #7
Your machines will last longer than you will!
/ Oil Change interval #8
My 3130 calls for every 100 hrs and filter every 200 hrs. Cheap insurance to do the reg. maintinance..
350 hard hours on my beast. Skypup, do you notice any improverd performance with the Synethetic hydraulic fluid?
I I've been using shell Rottella and SUDT
And what are the NAPA filter numbers again?
Thanks, Mike.
/ Oil Change interval #10
Mike, ther real need for the hydraulic fluid in the L-39 is no so much synthetic, but multigrade. The SUDT and the Amsoil Hydraulic fluids are both multigrade 10-20 viscosities, the SUDT is not synthetic but the Amsoil is. Either one will be good for 400 hours, the synthetic may have a little more resilence in either extreme hot or cold environments compared to the SUDT, but Kubota's own peer reviewed SUDT publication in the American Auotmotive Engineering Societies publication showed it works well down to -20*c.
In my experience, they both work excellent with zero drawbacks. I did try UDT once in my L-3130 GST and it was absolutely awful on the tranny and shifts, immediately took it out and replaced with SUDT at that time.
I think your Shell Rotella T 5W-40 and SUDT is plenty good.
/ Oil Change interval #11
Jimbrown said:
I think you read your manual wrong. 50hours is the first change after that it should be 200 hours almost all Kubota products are that way. Lookee here
Kubota Tractor USA - Quick Reference Schedule
Correcto! The PRESENT chart for those "L" series tractors ( and also the B2630 and B3030) state FIRST change at 50...the next at the 200 hr mark...and then every 200 hrs!
/ Oil Change interval #12
That is a Kubota Generic chart not for a specific model. Could be for a lawn mower. Says to check manual that came with tractor which I did and it says oil every 100 HOURS and filter every 200 HOURS.
40ft Shipping Container (A65583)
40ft Shipping...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
