pdesnoyers76
I have a Husqvarna YTH22V42LS and would like to change the oil. The tractor move slower now then when it was new. Probably it need a cleaning too. It has 115hrs. I will be replacing the oil with 5w50 full synthetic but I was thinking of adding 200 ml of Lucas Oil stabilizer also. I used that in the past for different application with success. Ex. I had a snowmobile Yamaha RX1 that were known for chain case failure because of heat. You also had to replace the chain every 8000 km. I always added 100ml of Lucas with every oil change. After 13000km, the chain was still within spec even with a pull test. Also the chain case was running much cooler. What you guys think?
