Oil Change for John Deere 2955
   / Oil Change for John Deere 2955 #1
mkt
Greenville sc
John Deere 2955 / Kubota SVL 90-2
I need to change the engine oil in my JD 2955.
Question: What oil should I use?
Is the Shell Brand Rotella at Walmart OK to use or Must use John Deer Brand?
What weight of oil also?
Thank you..
   / Oil Change for John Deere 2955 #2
Don't have to use JD oil, but why not use it? Can't be because of the cost as it is so little more.
But it is your tractor to do as you please. It is your investment to keep up, unless that is not important to you. just sayin...
   / Oil Change for John Deere 2955 #3
I've been using 15W-40 engine oil in my JD 4255 since I bought it in '93. It now has 11,400+ hrs on tach with no engine overhaul. IMHO Shell Rotella T is good oil
TxJim,
Thank you sir... Wasn't sure... Walmart is very close to me and JD dealer is a quite a drive.. I already have the filter,,
Thanks again>>
   / Oil Change for John Deere 2955 #5
I would go with a real JD Filter or a WIX equivalent. Rotella Triple T oil is good enough. There are better oils but the stuff is entirely acceptable.
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
