Oil & Fuel Oil and fluids - maintenance for 1301D
   / Oil and fluids - maintenance for 1301D #1
Adri122
Granada Hills, CA
Yanmar 1301d
Hello all. I'm new here :)
I have a 1301D and the gentleman I purchased it from no longer sells or maintains tractors.
It's due for an oil change but I'm not sure what kind of motor oil I should get or how much it needs.
Also not sure about the other fluids/items I should be checking out. Any advice would be greatly appreciated!
Adri
   / Oil and fluids - maintenance for 1301D #2
Adri
Welcome:thumbsup:.. Use any diesel rated oil. Don't know how much your mod will take.. Hyd fluid should meet JD 303 specs
   / Oil and fluids - maintenance for 1301D #3
Fluid & Oil Types I would put in about 3 quarts and start checking the dipstick. Once you get it in filter and correct level you will know next time what the capacity is.
If you go for a transmission fluid change be sure and pull and clean the metal strainer located behind a triangular flange low on the transmission. I don't know just where it is on the 1301. Maybe somebody out there knows and will respond.
Thanks for the tips!
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
UNUSED AGT QUICK ATTACH SEEDER DRILL (A51248)
UNUSED AGT QUICK...
John Deere 5400 Tractor with Loader (A51573)
John Deere 5400...
