Oil & Fuel OIL AND FILTER FOR LT 1046
   / OIL AND FILTER FOR LT 1046 #1
kgkx125@hotmail.com
I OWN A 2005 CC LT1046 WITH A COMMAND 23HP VTWIN - THIS MOWER HAS BEEN EXCELLENT FOR ME. I MOW APPROX. 1 ACRE WITH THIS MOWER-THE ONLY COMPLAINT I HAVE IS THAT OEM BLADES WEAR QUICKLY- ALSO I HAVE STARTED USING A WIX 51516 OIL FILTER AND ROTELLA T 15W-40 OIL- CAN ANYONE GIVE ME PROS OR CONS WITH THIS OIL FILTER AND OIL?
   / OIL AND FILTER FOR LT 1046 #2
Your post makes my head hurt (caps lock?). Yep, Rotella 40wts and Wix filters have been talked about lots of times. I've been running Rotella-T 5w-40 and wix filters since about 10hrs on my 2544. Good stuff. Are they needed? I say no. Only for those who get a warm and fuzzy feeling. Walmart 10w-30 and $2 filters changed regularly will probably yield the same exact result.
Joel
Thanks for the reply- sorry about the caps lock-I'll try to remember to lose the lock
   / OIL AND FILTER FOR LT 1046 #4
Also keep in mind, you can use a longer oil filter if you wish. I use the Napa/Carquest/Wix version of the Motorcraft FL400/Fram PH3600 on my Kohler Command 20. It's twice as long as the OEM filter. I believe you have the room out the side to go long if you want. More oil holding capacity is a great thing for an engine IMO.
Joel
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
Quick Attach Pallet Forks (A47384)
Quick Attach...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
