Oil additive Zn PO4 works in cast iron engine
   / Oil additive Zn PO4 works in cast iron engine #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Since this discussion has gotten a lot more scientific lately, here is an interesting article re the additive Zn PO4. Under enough pressure this molecule complexes with itself and doesn't squish out between 2 metal surfaces thus supplying lubrication. The kicker is that that pressure is only possible in cast iron vs cast aluminum. Cast aluminum deforms before that pressure is reached.
BTW, Science News is a 1st classs weekly magazine that follows many aspects of science and technology. They always give the references and twice a year print an index issue. It has won my awards for scientific journalism from Columbia U and U of Missouri. Every kid 13-14 y/o should be reading this plus anyone looking to keep up with science.
Science News
Science News Online
Week of March 12, 2005; Vol. 167, No. 11
Slick Surfaces: Pressure builds to make better motor oils
Alexandra Goho
Motor oil's protection against the wear and tear of steel engine parts takes effect only at high pressures, according to a new study.
The analysis reveals the molecular behavior of a common lubricant additive, whose mode of action had remained mysterious since the additive's introduction in the late 1930s. Understanding the additive's action may lead automotive engineers to design more environmentally friendly lubricants for steel as well as products especially suited for lighter, more efficient aluminum engines.
Zinc phosphates have long been the most common lubricant additives for protecting steel parts, such as pistons and cylinders in car engines, against wear when they contact each other. Through trial and error, researchers have looked for new additives, but none has outshined the zinc phosphates.
"People traditionally tried a whole bunch of lubricants and found that some worked and some didn't, but it wasn't always clear why," says Mark Robbins, a friction specialist at Johns Hopkins University in Baltimore. "Without understanding why something works, it's very hard to figure out how you would select a different lubricant that might address a slightly different problem."
Zinc phosphate has its problems, among them a tendency to break down and clog an engine's catalytic converter. That effect increases the carbon monoxide released into the atmosphere.
Also, the additive doesn't work well on aluminum surfaces. Compared with a steel engine, an aluminum engine can reduce a car's weight by 10 percent, improving efficiency by about 7 percent. So, the automotive industry is "very eager" to come up with new lubricants, says Martin Müser of the University of Western Ontario in London.
In the March 11 Science, Müser and his colleagues describe computer simulations in which they investigated the effects of pressure on clusters of zinc phosphate molecules. Initially, each zinc atom is bound to four oxygen atoms. As the pressure goes up, the zinc forms additional bonds. At about 17 gigapascals, the pressure at which unprotected steel deforms in less than a nanosecond, each zinc atom in the simulation shows six oxygen bonds. This creates a highly connected molecular network that forms a dense, rubbery film and protects the metal.
Müser noted that 7 gigapascals, the pressure at which aluminum instantly deteriorates, was too low to produce that tightly knit network. This might explain why zinc phosphate fails to prevent abrasion on aluminum surfaces. The group's findings suggest that an aluminum engine would need an additive that can form networks at low pressures.
"What's interesting here is that pressure is all that's really needed to make these films form," says Robbins. Other researchers have suggested that changes in engine temperature or chemical interactions between the additive and metal surfaces trigger a lubricant's function.
With funding from General Motors, the University of Western Ontario team is now screening elements other than zinc that might form three-dimensional networks similar to those found in the zinc phosphate films.
   / Oil additive Zn PO4 works in cast iron engine #2
<font color="blue">Since this discussion has gotten a lot more scientific lately...</font>
That's one adjective for it. Pedantic would be another. /forums/images/graemlins/smile.gif /forums/images/graemlins/tongue.gif
   / Oil additive Zn PO4 works in cast iron engine #3
Zinc is good in cars, motorcycles, tractors etc. Zinc is great for corrosion inhibitor, anti-wear additive, detergent, extreme pressure additive etc.
I also have never had a problem with the high levels of Zn in Amsoil. Never replaced a "cat" to date!
I think, again think Zn will be getting phased out very soon due to EPI blah blah.
   / Oil additive Zn PO4 works in cast iron engine #4
Think again, currently there is no substitute for ZnPO4, although scientists are working on it, they've been working on it for 60 years now and nothing new is on the horizon....
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
