Oil add to 2025R by dealer
   / Oil add to 2025R by dealer #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I got a bill for $25.70 for parts when they did the PTO button and Ujoint grease. Said they added some 5w30 oil to the engine. Told them that's bad business of not getting it into the other charge ($476) and that it should not have needed oil. Last time I checked it, it was bright and clear and full.
Anyway. Notably that they used 5w30, just like is speced for our VW TDIs for eons in all kinds of climates here.
Don't need 40w for a diesel engine.
Ralph
   / Oil add to 2025R by dealer #2
For years 15W-40 was THE recommended oil for diesel engines. Check your owner's manual for oil recommendations. There is a wide range of recommended oils for the newer tractors and yes, some even recommend 5w-30. The important thing to watch is the API rating and whether it's recommended for use in a diesel engine. Some oils are fine in either diesel or gasoline engines.
   / Oil add to 2025R by dealer #3
Many times a new engine will use some oil until it is broken in.
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
