Ohio power show
   / Ohio power show #1
trailertrash
Bronze Member
Clark Co. Ohio
1961 ford 971
Does anybody know if power trac is going to be at the Ohio power show? I just looked at the attendees list and did'nt see them listed. Anybody around the central Ohio region have a power trac that a person could drop by and eyeball ? I'm real curious about the physical size of the 400 series.
   / Ohio power show #2
<font color=blue>I'm real curious about the physical size of the 400 series.</font color=blue>
If you back it into a full sized pickup truck bed(with the tailgate removed) and make the hitch on the rear touch the front of the bed, the front wheels are about a foot from the rear of the bed. If you have an attachment on the quick attach, it will settle down on the rear over the bumper, quite nicely. It fits between the wheel wells with a couple inches on each side.
   / Ohio power show #3
   / Ohio power show #4
Power Trac will not be at the Power Show in Columbus but, according to Christy, a show she called "CENTS"...It was a "nursery" only type show...I couldn't find it in a quick search, but I would call the Columbus Chamber of Commerce for more detail.
   / Ohio power show #5
Here's the link to the Ohio Nursery and Landscapers Association that's putting on the CENTS show in Columbus, OH. Power Trac will have a booth there, but I can't figure out if this show is open to the general public:
<A target="_blank" HREF=http://www.onla.org/>http://www.onla.org/</A>
   / Ohio power show #6
Hey, CRJCaptain,
Welcome to TBN. I have lots of family on my mom's side down near you. Beautiful country /w3tcompact/icons/smile.gif
   / Ohio power show #7
It's closed to the general public, but anyone could get in that wants to register.
From their site:
<font color=blue>AN INDUSTRY SHOW!
"CENTS" is a show specifically for people engaged in any aspect of the green industry; grower, garden center, landscape contractor, landscape maintenance, turf grass and arborist. The show is closed to the general public. There is no cost to attend the show, but all visitors must be registered and wear a badge. There is a charge to attend the OSU Nursery Short Course.</font color=blue>
   / Ohio power show #8
<blockquote><font size=1>In reply to:</font><hr>
Hey, CRJCaptain,
<hr></blockquote>
Hey, thanks. In fact, many thanks to all Power Trac afficianados on this forum...it's been an incredible resource. I've been lurking and reading through all the PT posts over the last couple weeks.
A little background...we're going to be building a new home here in northern KY on 22 acres, so I'm in the market for a compact tractor. I happened upon this website while conducting an Internet search for all things tractor...Was reading a thread on the Kubota forum that you had contributed to MossRoad, clicked on your website link and stumbled onto this amazing Power Trac product line.
Bottom line: I was all set to get a Kubota BX2200 or 7500, now I'm 98% sold on the PT 425 to do all the jobs I'll need to do on the property.
I plan on making the pilgrimmage to Tazewell in the not too distant future to test drive the machine. I think while I'm there I'll suggest they start cutting you commission checks, MossRoad.../w3tcompact/icons/grin.gif
Of course, as has happened to other PT'ers on this forum, I'll probably go down there to look at the PT425 and come back with a PT1850 /w3tcompact/icons/shocked.gif
I think that this might require a few more persuasive discussions with the wife.../w3tcompact/icons/love.gif
Anyways, thank you TBN and all you PT people out there!
Regards,
Dean
   / Ohio power show #9
<font color=green> Bottom line: I was all set to get a Kubota BX2200 or 7500, now I'm 98% sold on the PT 425 to do all the jobs I'll need to do on the property. </font color=green>
CRJCaptain,
I was in almost the exact same situation about a year ago. I was also strongly considering a small Kubota. I was one day away from buying the Kubota when I changed my mind and went with the Power Trac. Some of my thoughts (all should be construed as opinions, not facts):
Kubota
- great resale value if you ever change your mind or just want to try something else
- is well suited to “traditional” farm tractor stuff and fairly suited to landscaping and lawn duties
- anything bigger than the BX or 7500 is harder on the lawn if you go fast and make sharp turns
- attachments in the rear can be a pain to connect and use (i.e., you are frequently looking over your shoulder)
- except for the BX, can get scary to use on slopes
Power Trac
- resale value is iffy but probably acceptable if you are patient and willing to deliver the tractor to a private owner
- is best suited to lawn care and landscaping, and not well suited to “farming” activities like plowing
- is easier on the lawn than a traditional tractor design, or any other design I have seen
- is easier to use with attachments due to the quick attach on the front of the tractor
- works great regardless of the terrain
Overall, I went with the PT because it is the optimal design for mowing and FEL work.
Also, I have found that the quick attach feature increases the tractor’s productivity significantly. For example, almost anyone will tell you that a FEL is not the optimal tool for excavation. The main reason is that the basic design spreads the digging force out over a large surface area, as opposed to a backhoe for example. However, by quickly attaching a PT plow (potato digger), I can easily break up the ground down to about 5”. I then switch to the bucket a scope up the dirt. I excavated an area about 4” deep using this technique (I will post some pictures if I can remember to bring my camera home from work). Now this same technique could have been accomplished with a traditional tractor with a rear mounted plow and a front mounted FEL. However, because all attachments mount on the front of the PT, I was able to finish the job quicker and with greater precision (being relatively inexperienced) than would have been possible if I had used a traditional tractor.
Further, I find I can quickly change from one activity to another. Continuing the excavation example, I could move from excavating to mowing the lawn in 15 seconds. With a traditional tractor, one really wants to remove the mid-mount mower if the tractor is to be used over rough terrain, like excavation work. And many folks like to take the FEL off to mow. While it’s simple to make these changes with the Kubota, you are still talking about several minutes of activity and getting on your hands and knees to deal with the mower. With the PT, it’s only a matter of seconds to make these changes, all without leaving the tractor (although it is easier to get off the tractor to connect the two PTO hoses).
   / Ohio power show #10
The BX is a fine choice, too. I looked at those, the JD4100, the NHTC21D(very comfortable tractor) and a CUB as well. All were fine machines.
I had my heart set on Deere at the start(most dealers around here were not to my liking) and got such a wide price spread it made me dizzy. Realized the NH was much more comfortable(couldn't fit on the JD4100). Realized the Kubota BX was an awsome machine for the price, reliability, resale and service oriented dealers. The CUBs were kind of pricey. Then came the Power Trac. I knew it was different and no dealer support. However, after seeing one operate in person, speaking to several owners(both professionals and home owners) and knowing that I can do all of the maintenance and major repairs myself, I took a chance. I don't plan on selling it and am in for the long haul. So far, after almost 100 hours, I am very happy. Except for the whimpy inflatable tires on the brush hog(see other posts on this if interested) I am entirely satisfied with our purchase. The factory support has been excellent, as others will attest. They will hold their trade secrets close to the chest, but that is understandable in my opinion.
Be sure to test drive all of the brands that you are considering. Test drive them all. Compare the specs and get the one that is right for you, even if it isn't a Power Trac. You won't be sorry, no matter which brand you go with. They are all fine machines. /w3tcompact/icons/smile.gif
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
