Oil & Fuel Off the wall LK3054 transmission filter cartridge numberr Help please
   / Off the wall LK3054 transmission filter cartridge numberr Help please #1
ron45
N.M.
Kioti LK3054XS
Does 265W134B seem like the right number? I've never ordered this part before. It's a canister w/large nut head on the bottom. I sez re cartridge, clean or replace. I may have to be clean untill I can get a realistic number. NAPA where I get Kioti's oil filters can't cross it to another number. I got that number from a page in the owner's manual. I can't find the page I got that number from. Maybe I was channeling Ho Chi Minh! But I didn't make it up. Love to find a replacement. If I can't how are these cleaned? swish around in transmission fluid? Saw a commercial on utube about ultrasound cleaning. That should work well with many things, air filter?Probably pretty expensive. Might could build one with a bucket and the u.sound generator.
Ron
   / Off the wall LK3054 transmission filter cartridge numberr Help please #2
Hey Ritcheyvs, yes I'd been to that site before but for a different part and when I tried to search for the part I got error msgs over and over. I figured they wanted me to open an account.
So I'm very grateful for your link. I now have a part number for that company, and maybe I can cross ref. the number to a place closer to my location. Thank you for taking the time to help.
Ron
   / Off the wall LK3054 transmission filter cartridge numberr Help please #4
... I now have a part number for that company, and maybe I can cross ref. the number to a place closer to my location. ...
Those are generally Kioti part numbers.
   / Off the wall LK3054 transmission filter cartridge numberr Help please #5
The filter is a metallic mesh; doubtful you'll find one anywhere but Kioti. I use a shallow pan and any solvent you might have available; put just enough solvent in the pan to flood the outer surface of the filter( not enough to cover the inside surface). Roll the filter element in the solvent so as to cover all the outside surface of the filter and using compressed air, blow from the "inside" of the filter out; never blow into the filter as you may in-bed debris into the mesh. Repeat this process until all debris is removed
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
Champion C80 B Motor Grader (A50322)
Champion C80 B...
Gas Powered Golf Cart (A50515)
Gas Powered Golf...
Tool Box (A47384)
Tool Box (A47384)
1995 1063 Corn Head (A50514)
1995 1063 Corn...
