Off season tire pressure?
   / Off season tire pressure? #1
BWSwede
Washington
Yanmar
I don't use my trailer during a 5 month stretch during winter. I have Load Rating E tires that I run at 80 psi. Should I decrease the pressure during the off season to help lengthen the life of the tire?
Thanks,
BWSwede
   / Off season tire pressure? #2
Several tire website recommend if storing tires while on the rim they should be inflated to 50% of recommended pressure. They should also be off the ground (I assume so they don't develop flat spots). If they are outside I would think they should be covered to protect from the suns UV light to prevent sidewall checking. None of the sites I looked at mentioned anything about them being attached to a vehicle just that they are on rims.
   / Off season tire pressure? #3
The best thing you can do for any tire that sits is getting the vehicle they are on jacked up. I put 2 of my trailers on jack stands. My other trailer is used bi weekly at a minimum.
Mine all live in barns but tire covers are the next best thing.
Chris
   / Off season tire pressure? #4
I remove my trailer tires and store them inside the house for the winter. I have over 50 tires on everything from wheelbarrows to trucks, when not in service jack'em up. Never heard of reducing the air pressure.
   / Off season tire pressure? #5
Never heard of decreasing pressure. I would think that would help cause flat spots. Jack the trailer up or at least cover the tires to protect from UV. Take the trailer for a spin every month if you can. That might help.
Thanks for all the suggestions. Will act upon all of them except for the one about bring tires into the house. I can tell you right now that won't float with my wife, so I am not even going to ask.
BWSwede
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2008 Jeep Wrangler SUV (A53117)
2008 Jeep Wrangler...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2021 BOBCAT T64 R-SERIES SKID STEER (A51246)
2021 BOBCAT T64...
