Off road dump trailer options
   / Off road dump trailer options #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
I'm looking for a "smallish" (that's a word right?!?) trailer to tow behind my 45hp tractor. I'll only be using it in the woods but I suppose if I had it registered I'd possibly use it to pick up a yard or two of mulch once a year, but roadworthy isn't important to me.
What are the better quality dump trailer options out there? I want something narrower than my tractor so a max of about 5' wide and the shorter the better, I'd say MAX of about 10-12' total length (including tongue). I want max maneuverability out of it.
I need to be able to dump it by hooking up directly to the tractor hydraulics, I don't want a battery powered dump because most dumping will be short runs and not much time to recharge the battery.
Please let me know what you have and what you do and don't like about it. Also, for sense of scale, I'd love to see some pics of a trailer and tractor so feel free to post them.
If there is a me gathered on this already point me in the right direction.
   / Off road dump trailer options #2
there are a few companies that make nice ones with walking beam axle that are offroad only, but they are pricey. Look at John bm manufacturing, pronovost, and artsway which bought out agrotrend. Also king kutter makes smaller ones and I think rural king has a few on thier website. I think the pronovost has fold down or removable sides, and also has a 3 way dump option
   / Off road dump trailer options #3
It sounds like a barge wagon would be just the ticket for you. Watch Craigs List for one. They come up all the time in the bred basket of america but maybe not so often in central MA.
   / Off road dump trailer options #5
Not very much experience here at all but I think a 2 wheeled trailer is much better for rough terrain. With a tandem axle, when turning one set of wheels will be forced to slide sideways and possibly peel a tire off the rim. If others have a different view, please post.
Al
   / Off road dump trailer options #6
Al
Running a tire off the bead is usually accomplished by those who never check tire pressure. You are not gonna run a properly inflated tire off the rim. Walking beam axles are the bees knees.
Berkelmans Welding Hydraulic Farm Dump Trailers and Manure Haulers
These guy's go down to 6' long x 5' wide 9 (box) 2 ton cap.
That 2 ton model looks perfect! Exactly what I'm looking for. I emailed them with some questions and an idea for price. Thanks for the link.
I also really like the Pronovost trailers mentioned as well. The smaller ones that I'm interested in don't appear to have the 3 way dump. The "503" and "504" models are also right in the size range I'm looking for. I knew they made good quality snow lowers but I forgot that they made trailers as well. (Actually not sure I ever knew that)
I'd love to see some photos of any of head tractors and trailer combos!
Does anyone have any experience with the style that dumps using the tractors hydraulics? I would assume it would dump quicker and more powerful than the standard battery style dumps????
   / Off road dump trailer options #8
Hello Piston,
The trailer is going to dump only as fast as your hydraulic system
will let it as the weight of the cargo and the weight of the dump box
is what you are dealing with as resistance
Most of them are single acting cylinders/my MAXIM single axle
trailer is a two ton dumper is five feet by seven feet with a 1 5/8" ball receiver.
It takes about 10 second to the fully raised position to dump a load of whatever
you are hauling.
It has 70 cubic feet of capacity without the side boards in the stake pockets.
I used it to bring home 33 full cords of firewood from my fathers cleared
housing lot that had 2nd growth hardwood weed trees in it.
I installed tie downs in the dump trailer with the help of a close friend several years ago
and I am glad I did as it saves me $70.00 for every time I need to take the current mule
to the JD Veterinarian and it will fit a JD series 1 with a loader and a Pronovost rear mount
snow blower when and if I am able to buy them.
I would not hesitate to tell you to buy a road legal end dump as the deep cycle batteries
work very well. I replaced my first battery this past fall after 5 years of intermittent use-
being semi annual dump runs with coal and wood ashes and garbage, scrap hauling,
mule transport to JD Vet for a new drive belt and lube, oil and filter job and other reasons/trips.
My road legal end dump has tires with G rating if I remember correctly.
   / Off road dump trailer options #9
I have a Pronovost, a 512 I think. Taking a road legal trailer in the woods behind a tractor is a fools errand. it won't be road legal when it comes back out. Offroad trailers have more ground clearance and less wires and lights. Marine batteries and electric over hydraulic units are a waste of money and unreliable if you have a tractor with a rear remote valve, providing the tractor is big enough to pull and stop the trailer to begin with. I say unreliable because if the battery goes dead, you do not dump the load.
Thanks for the additional replies. I like the heavy build quality of the off road versions can what I've seen on the road, although I've never seen a true off road version in person.
I did get a reply back (very quickly I might add) from Berkelman welding regarding the 2ton dump. It's 5'x6' and weighs 700lbs. The delivered price was $3200 from Canada, seems pretty reasonable compared to what I was expecting.
I'm going to look at the cost of a pronovost as well. I wish they offered the 3 way dump in a smaller version, seems handy.
The main reasons I want to stay away from a battery operated dump, are I will leave it for months on end without touching the trailer, through the cold winters, and most all my use will be very short runs, maybe 200 yards or so I'm just guessing, but I won't ever give the battery a chance to recover with long idle times between dumping. Also, it's just one more "system" that can have issues. I want to keep it simple, but rugged.
John Deere 7300 MaxEmerge 2 4-Row Planter  Adjustable Row Spacing (A44789)
John Deere 7300...
2009 Grasshopper 430D 72in Zero Turn Mower (A42744)
2009 Grasshopper...
2018 Dodge Charger Sedan (A42744)
2018 Dodge Charger...
2020 PETERBILT 567 (A45046)
2020 PETERBILT 567...
New/Unused 14ft Bi- Parting Iron Gate (Deer Design) (A44391)
New/Unused 14ft...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A44789)
80in HD Tooth...
